Ga16de And Sr20de Motor Mounts
1 reading
3.2K views 5 replies 5 participants last post by  TopLevelB13
#1 ·
Are these motor mounts the same for both engines??
#4 ·
The actual mounts (the rubber w/ housing) between the GA and the SR are the same for the firewall, passenger side, and the dog-bone. It is the mount brackets that are diff't. If you are looking for a spare set of mounts (for ES or Prothane) you can get the GA's, and then just bolt them to the brackets. I can post the part numbers if you want.
Good luck,
Josh
